Why would this wiring be jumped?
Re: Why would this wiring be jumped?
its jumped so the bike will start without you pulling in the clutch .
trouble is it tells the computer to run the start up map all the time.
un jumper it and if the switch is faulty replace it .
it will restore the correct function of the ECU and run the correct fuel and ignition maps.
more info at wotid.comwww.cycleinnovations.com.au
Originally posted by The Ring-In View Postits jumped so the bike will start without you pulling in the clutch .
Well I just hooked it up the way it should be, seems to fire up when the clutch is pulled. I guess that means it works?
Its a safety requirement by law so the bike does not start and toss you off if its in gear.
downside of jumpering it is it changes the ECU mapping and thats not good.
put it back to std and enjoy the bike running properly.www.cycleinnovations.com.au
Did they have a remote start on it at one time? I see them bypassed for them often.- If you find this site useful kick us a few bucks. <a href="http://www.tlplanet.com/forums/billspaypal.php"><b><font color="blue">Tip cup</font></b></a>
Results,
MORE POWER AND SMOOTHER!
I would honestly say by about 1/8.
Still feels and sounds a little rough but, all I have to compare to is a inline 4cyl 1100cc Yamaha motor.
Ill have a service done by the dealer and see if it helps any.
It just turns on a leaner idle mixture map so the plugs don't foul when idling. Some people say it also changes the ignition advance for idling, don't really know whether it does. I think the switch is normally open and closes when you squeeze the clutch, so indeed having it jumpered makes it always run on the idle maps. The ECU has the same reaction to being in neutral instead of in a gear too, that's why you need a smart TRE so the ECU still sees neutral. If it sees neutral OR the clutch squeezed, it uses the neutral idle maps.It's about control skill; this is a motorized dance for joy and not Russian roulette.
It also causes the ECU to run the fuel pump when it sees the starter button signal too instead of the ECU waiting for crank and cam sensor pulses.
Here's the stuff I collated about it >> http://wotid.com/tls/content/view/18/56/
Originally posted by Brat View Postx2 you usually have to depress the clutch to start it. that cheats it so you dont have to. i have that on mine too."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Your thoughts?
Anybody spare a factory air box lid?
