The left blinker is good front and back.
Blinker is out but not burnt out.
My rear right blinker is not working causing the front right blinker to flash super quick. I used my multi meter to check for power and nothing is showing. Tracing the wires to find the problem is going to a very long process. Has anyone ever experienced this type of problem? I wonder if their is another fuse, switch, or wire that went bad or is unplugged?
The left blinker is good front and back.Tags: None
Re: Blinker is out but not burnt out.
lift the hump and swap the right blinker wire for the left etc. does it blink now on the opposite side.
if so its the blinker if not its the wiring.www.cycleinnovations.com.au
Originally posted by The Ring-In View Postlift the hump and swap the right blinker wire for the left etc. does it blink now on the opposite side.
there will be plugs connecting the wires just inside the rear tail peice were the blinkers bolt onto maybe your right rear one is faulty id check that first(im sure some one else has said this too?)Mod's to bike so far: Projector HID lights (blue halo's),Vandriver parts (CCC,red PP,red clutch cup,brake F&B cups, Blue top triple, Blue front sprocket cover), Aprilia Brembo Wheels,520 sprocket & chain conversion( to suite the Aprilia wheels),charging mod, headlight realy mod, bitubo rear shock, custom black with heavy blue pearl paint, fold away billet levers
so all is good with the blinkers nowMod's to bike so far: Projector HID lights (blue halo's),Vandriver parts (CCC,red PP,red clutch cup,brake F&B cups, Blue top triple, Blue front sprocket cover), Aprilia Brembo Wheels,520 sprocket & chain conversion( to suite the Aprilia wheels),charging mod, headlight realy mod, bitubo rear shock, custom black with heavy blue pearl paint, fold away billet levers
