Just back from suzuki and still not fixed!!!
Ok so i brought my bike to HK power sports suzuki dealer. I had them sync TB's TPS it cost me $104 and now the bike runs worse then before!!! The tech said that i have a lean missfire and the bike is running way to lean! The bike is a 00' TLS with a 02' TLR motor. anyt help would be great! thanksTags: None -
Re: Just back from suzuki and still not fixed!!!
Most common reason for a lean TL is fuel filter in need of replacement.sigpic
PM Me for Help & Prices with GSXR/Busa Radial Fork Conversion Kits -
Can you describe the symptoms better?It's about control skill; this is a motorized dance for joy and not Russian roulette.Comment
it probably is lean.
You will need to do the TB sync again after you get eveything figured out.
Go through the fuel system. Start with the fuel filter, check the rail pressure, take out the injectors and have them cleaned.
Go through the vacuum sytem and make sure everything is connected correctly -you might actually want to do this first as vacuum plays a part in fuel pressure.Comment
symptoms: powerless under 3000 rpm's compaired to my buddys TLR same mods and at 3k RPM's it buck's skips and jerks above that it rips! strong power curve!Comment
is the filter in the tank? anf there is no codes! O and the tech forgot the code switch on my bike! So i got something out of the deal!Comment
maybe yours is jumped too?
Run over on: '98 TL1000S
Riding: '98 TL1000R fighter
Drooling over: '02 TL1000RComment
Do you have a Power Commander? If so remove it and test it without. If not maybe have the ECU zero'd out so you know you are are starting from a known baseline.- If you find this site useful kick us a few bucks. <a href="http://www.tlplanet.com/forums/billspaypal.php"><b><font color="blue">Tip cup</font></b></a>
- Want to help support the Planet? <a href="http://www.tlplanet.com/forums/payments.php"><b><font color="blue">Subscribe</font></b></a>Comment
nope no power commander! but i ordered a PC III pro today! it will be here weds then to the dyno sat.! im hoping for the best !!! if any one else has some suggestions please feel free!! thanksComment
Triumph 1050 Speed Triple
TLS naked project
Rebuilt motor from Sam, 04-06 R1 forks/brakes and wheels, Penske shock and spring + Linderman link, Big bore zorst with Ti Scorpion cans, TLS that needs some loving .Comment
