Tabs.. who knows how to fix them
  • Tabs.. who knows how to fix them
    Gorilla glue? Super glue? Duct tape?
    Thanks
    Re: Tabs.. who knows how to fix them
    super glue and baking powder works very well . T.L.
      There is a 3m product that is for plastic. Sorry I can't remember the number.
      "Screw you guy i`m going home." Cartman
      It's not the crash that kills you. It's the sudden stop.
        Plastic welding works OK for ABS, but nothing ever makes it quite as good as new.
          ABS Cement from Lowes or Home depot/in plumbing.
          "Don't find out the hard way..."
            I never tried that, people always recommended MAT4 or MAT5 or some such. But ABS plumbing glue will certainly bond the pieces together. The joint might be a bit more flexible afterward? Did you try it? How did it work?
              Black ABS pipe glue. Get a foot of pipe too. Cut some small pieces off with a handsaw and mix the shavings in with the glue to make it thicker. Use the pieces to reinforce the repairs.
              Prep your parts well by sanding off paint in the area with coarse sandpaper.
                what if the broken tabs are missing
                  I used stuff called "Plastic Weld" Was like an epoxy.
                  http://tl1000rmods.blogspot.com/
