quick question about throttle sync
  • quick question about throttle sync
    a quick ? about throttle body sync, i watched the video and to my best recolection my R model doesnt have the air adjustment screws that the S model has on its throttle body, so my question is after i get them synced at idle do i need to try and sync them at 2000 rpm like the video says, and if i do sync them at 2000rpm and i drop it back down to an idle and they are a little off what then without the air adjustment screws, do i just kinda find a happy medium with both adjustments? thanks from a stumped member
    Re: quick question about throttle sync
    You dont have air adjustment screws... lucky bastard... anyhow you need to do the adjustment according to the R manual. They are Similar.. but not alike. I am not familiar enough with the r for advice... Someone should chime in soon.
      Do you have the R manual?
      The R Manual
      Now ya do
      Full Yosh
      PC III
      Penske shock
      Braided lines
      SteveTLS TRE
      Rifleman 1/5
      Pazzo levers
      Vandriver tailrisers
      Modified Buell footpegs
      Custom Projector headlights
      GSXR forks
      TheRingin raised clipons
      Ohlins steering damper
      GSXR mirrors
      TLOTM Sept 2011
      BBOTM Nov 2011
        thanks itsmesteve got"r done! she runs so much smoother
