Busa forks
Re: Busa forks
Originally posted by stress71 View Postwondering what would be the advantages putting busa forks on the TLR, what mods would have to be done and what year would fit.Thanks.
______________________________
Ohlins rear, Traxxion Dynamics fork internals, Busa calipers, Woodcraft rearsets, TRE, full Yosh RS3-C, Zero Gravity Double Bubble, Rifleman throttle insert, GSXR rotors.
Re: Busa forks
Originally posted by tlrpunk View PostI think the internals are a bit sturdier. Sean (speedking) knows all about them. They are also longer than the TLR forks so you need to drop the triple a bit more to maintain the proper steering geometry.
Re: Busa forks
Mine are 05 busa forks, you can see the difference in length.
The factory valving and spring rates are softer, but the internals are slightly more substantial (beefier) IIRC from speedking's analysis.
The dropouts will need to be modified to fit a TLR fender.
