how long should the Galfer front brake lines be
if you can route them and still have a little slack (for full fork extension) you should be fine.
Just make sure when you run em, they are secured as to not be near rotating parts. Would suck to have the tire rub a hole in the line.It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
I thought the same thing about mine, but after I ran them side-by-side with my stockers I was relieved. They may look short, but they'll fit perfectly(if I ever get them installed). Just remember, the Galfers don't crossover, they both run straight from the mastercylinder.
Check
http://tlplanet.com/forums/showthrea...ht=brake+lines
There are measurements for you to check if you want.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
