Help!! Adjusting the TPS on my 1040
Re: Help!! Adjusting the TPS on my 1040
Oh man, usually it isn't that much of a hassle just be patient with trying to get it right.
I can't remember the rpm spec for fast idle, as I don't use it.Last edited by LiononaLeash; 08-21-2010, 04:47 PM.TL1000R: For those who like to drive high speed tanks
1200 middle and i believe the line should change @ 1400 good luckage is a state of mind
sigpic[IMG]
See my new thread...I think I figured out my problem....Freaking sealer in the gasket turning to jelly and plugging this beast up...until finally no fuel period! Anyone that puts this crap in their tank should be drawn and quartered!!!
For reference:
Idle ~1200rpm (don't go lower) Bar in the middle.
Bar to the top at around 1400rpm
Fast idle lever back to the bar = 2000rpm on a warm engine per the manual.
(2000rpm is very handy for track and twisty work as it takes a lot of the off-on throttle transition snatch away)."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Thanks for the input guys!!!I ended up breaking down and rewatchin the video on tps adjustmnent as I just couldnt seem to get it. Could not get her to run with the bar in the middle ...period. Then she died and would not fire back up...I thought I lost a cam pin again but nope...still had spark. I checked the throttle bodies and not a bit being squirted but the pump was priming. I didnt really want to take the tank apart but did so reluctantly. Glad I did now.
