front sprocket help
  • front sprocket help
    hey just working on the tlr last night got the HID lights in, bitubo installed, rear sprocket done and came to my hard part.... the front sprocket.
    i took the allen head out of the center then there is the 4 pronged thingy(i think its for the spedo sensor, not sure) that is in front of the 32mm nut. how do i get that off? thanks for the help
    Re: front sprocket help
    Air impact wrench.
    BBOTM January 2011
      leave in gear with chain on
      Shropshire UK
        pretty sure you should have not taken the chain off yet as you will not be able to get the front sprocket off without putting it in gear, which is bad due to the immense force needed to get that damn nut off... anyways once you get the allen screw out of the middle i think it (speedo sensor disc) just pulls out from what I remember... also if u dont have an air gun get a big (3 feet or so) pipe for a breaker bar and slip it on your ratchet handle that is what i did.. good luck!!
