Radial clutch master question
Re: Radial clutch master question
The Ducati/Aprillia 15mm works a treat
Full Yosh
PC III
Penske shock
Braided lines
SteveTLS TRE
Rifleman 1/5
Pazzo levers
Vandriver tailrisers
Modified Buell footpegs
Custom Projector headlights
GSXR forks
TheRingin raised clipons
Ohlins steering damper
GSXR mirrors
TLOTM Sept 2011
BBOTM Nov 2011
Here is the one that I'm using with a CNR lever.
http://cgi.ebay.com/ebaymotors/DUCAT...Q5fAccessoriesComment
go with the one steve recommended
I've felt it and it is absolutely fantastic.www.cycleinnovations.com.au
wwjd.......what would jimmy do.Comment
I'm sorry. I didn't read closely enough and now just saw that you were looking for the radial clutch. For that money, you should just go to the TLS cabled clutch setup. I love it so much more than the hydraulic. Notice that the "S" crowd usually doen't complain very muchComment
Scored this on Ebay for $137. It's off of a Duc 1098 and has a brand new CRG lever on it, and he is including the clutch safety switch also.Attached FilesComment
Great score!
With that lever you can adjust the lever position and the bite point of the clutch(adjustable on the m/c pushrod)Full Yosh
PC III
Penske shock
Braided lines
SteveTLS TRE
Rifleman 1/5
Pazzo levers
GSXR forks
GSXR mirrors
TLOTM Sept 2011
BBOTM Nov 2011
Clutch bleeds up real easy
What are you going to use for a fluid res?
I went to a lot of trouble to find one that had the switch and the res included as the were seriously expensive.
Lucked in and got a brand new one with switch and integrated res for about $100 .Then just needed a lever perch to use my shorty lever.(About $35 from Speedking.Damn he looks after us good)
Just looked at your pic again and there doesn't appear to be a switch attached.
Try to get it if you can!!Last edited by itsmesteve; 09-12-2010, 11:24 PM.Full Yosh
PC III
Penske shock
Braided lines
SteveTLS TRE
Rifleman 1/5
Pazzo levers
GSXR forks
GSXR mirrors
TLOTM Sept 2011
BBOTM Nov 2011
He is a tech at a Duc dealer, he's got an OEM switch. I have a small remote res I got from Ebay on the way also, I have a small alum bracket from my old race bike spares that I can mount it with. I have the exact same brake set up on my 91 GSXR street fighter right down to the rotors and calipers and I freakin love it.Comment
SortedFull Yosh
PC III
Penske shock
Braided lines
SteveTLS TRE
Rifleman 1/5
Pazzo levers
GSXR forks
GSXR mirrors
TLOTM Sept 2011
BBOTM Nov 2011
