plug wires
Re: plug wires
Our spark plug caps are removable, but I think the spark plug wire is soldered to the coil wire before the coil is potted in epoxy. So I dont' think our wires are even replaceable?
n2wheelies did a nice job replacing coils and wires with Nology.It's about control skill; this is a motorized dance for joy and not Russian roulette.
Re: plug wires
I have TLR coils and SV coils, haven't mounted either yet as I'm polishing the TLR engine mounts. Did you mount the SV coils on a TLR? Did you have to make special brackets? Were the high-voltage wires the right length? Did you use the SV plug boots?It's about control skill; this is a motorized dance for joy and not Russian roulette.
Re: plug wires
You can 'unscrew' the plug lead from the standard TL coil.
Les (TLDV8) has taken pictures of the lead removed and overlayed dimensions for replacement wires.
Here we go, found one:
Re: plug wires
Originally posted by cyclecamper View PostI have TLR coils and SV coils, haven't mounted either yet as I'm polishing the TLR engine mounts. Did you mount the SV coils on a TLR? Did you have to make special brackets? Were the high-voltage wires the right length? Did you use the SV plug boots?
Even when I switched to the cbr injectors which seem to be MUCH larger then the TL injectors I didn't foul the plugs on the way to the dyno. When I got there, I found out with the new injectors I was no leaner the 10 to 1 afr anywhere in the map......so they have done pretty well for me so far.
Re: plug wires
CBR injectors? I hadn't heard about that, but I want to know more. I have very high-compression pistons and vee two cams, shortened and bored TLR throttle bodies. But stock displacement. Haven't installed it yet, much less fired it up. But I'm very interested in an injector upgrade and possibly an adjustable fuel pressure regulator before I attempt re-programming the ECU (I already dug out the potting epoxy and soldered the header onto the printed circuit board).It's about control skill; this is a motorized dance for joy and not Russian roulette.
Re: plug wires
Originally posted by cyclecamper View PostCBR injectors? I hadn't heard about that, but I want to know more. I have very high-compression pistons and vee two cams, shortened and bored TLR throttle bodies. But stock displacement. Haven't installed it yet, much less fired it up. But I'm very interested in an injector upgrade and possibly an adjustable fuel pressure regulator before I attempt re-programming the ECU (I already dug out the potting epoxy and soldered the header onto the printed circuit board).
Re: plug wires
So you can change the wires. Now there is another question. Could you use some auto racing build your own wires and make your own. I have some excel race build wires leftover. They are 7.5 or 8mm. They held up very well with my 70000volt thunder bolt coil I had in last hot rod. It would melt everything else.
Re: plug wires
Can you install and use GSX-R600/750/1000, "in the head", type coils and wire them up to work?Last edited by bemdoubleyou; 09-05-2010, 12:56 PM.
