new barnett clutch srings?
Re: new barnett clutch srings?
The spirng post into the spring post base (half the cam set) should get permanent red loctite. I don't know what the book says, that's just what I say. darn it, where is my bookIt's about control skill; this is a motorized dance for joy and not Russian roulette.
Originally posted by cyclecamper View PostThe spirng post into the spring post base (half the cam set) should get permanent red loctite. I don't know what the book says, that's just what I say. darn it, where is my book
(And possibly Blue on the bolts)"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Originally posted by jaymami View PostHi guys.
Do you know where can I get these Barnett Springs for my TL1000S (1997)?
Thanks a lot!2001 TL1000R -Full Yosh Ti cans,bitubo shock,TRE,PC2,BMC filter,moto-style no cut sliders,joe v airbox,manual fan switch,16-40,speedo-healer,UFO,pedro gpi, corbin seat.
2001 DRZ400E - Yosh pipe, race-tech suspension, moose skidplate,msr rad. guards,acerbis handguards,cfc caseguards,mcct, JD jetting,renthal bars,acerbis hand guards.
Originally posted by Steve TLS View PostI don't know what the book says. If I recall correctly, I used Green
Originally posted by Geekly View PostSo.....at the risk of sounding retarded...eh, too late, the clutch spring bolts should be loctited? I've been running the Van's setup for a little while and just torqued the bolts, no loctite. The stock bolts came out without any trace of thread locker being used so it never even crossed my mind.Frank Corona
I ride more than most people do. I got the tlr in june and logged 12000mi and still counting. I have had my clutch apart several times. Bolts haven't ben loose yet. When I get the clutch issue solved I will use some blue loctite. I want to get them out without the risk of screwing my van plate up.
It was slipping. When you get on it hard. I don't know what oil was used in it. I put synthetic blendin it. Well new barnett springs. Same thing. New barnett clutch kit 8+1 same thing. Still slip. Took back lash drive out. It had some ware on it re ground edges. Same dam problem. After research the syn oil of ben prob. I changed oil back to regular. Cleaned clutches miked everything and still slip. When I get the extra money I'm going with new style factory clutch kit 9+1. All new. I give up. Drive till blows or the cash comes.
Synthetic oil was NOT the problem. Some folks have found the Barnett and other aftermarket plates to be the wrong thickness. You probably need to start with measuring all the plates and seeing if they are within spec. I reckon that just might be your problem. As a rule, the clutch on the TL is one place you are generally better off sticking with OEM parts."The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."
