Stupid Lever Question
OK, I'm about to order new levers for my TLR. Problem is I have TLS cable clutch. My question is are the TLR and TLS brake levers able to be swapped?Tags: None
Re: Stupid Lever Question
Nobody makes you buy two sets if you can specify what you need (or find a better vendor). The stock TLS & TLR non-radial brake masters are different bore but I don't know whether the levers will interchange?. Suzuki sells them differently for TLR and TLS.
TLR lever with knocker but not screw 57420-33E01
TLS lever only: 57420-32C00 lever with screw & knocker: 57300-32C10It's about control skill; this is a motorized dance for joy and not Russian roulette.
You can use a TLR lever and a TLS MC and visa versa. The OEM are different in that the TLS has 4 adjustment positions and the TLR one has 6 positions"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
thanks steve, I was going to post I got in contact with different sources and all got the same answer. they fit
