Not again!
Not again!
Well I think my S ate another set of front wheel bearings again. This is the third set and it is the same bearing on the left hand side of the front wheel. I when riding I can hear a loud clicking and popping sound. Every time I have installed the bearings I have put them in the freezer for a hour or so then heat and greased the inside of the hub on the wheel. The bearings just simply press in by hand. I always torque to spec per the service manual. So I'm at a lost as to why this keeps happening.My build thread --->http://www.tlplanet.com/forums/showthread.php?t=79793
Wichita, Ks.Tags: None
Re: Not again!
After debating some opinions and suggestions, I have concluded that my bearing hub spacer is fooked up and is causing too much side load on the bearings when torqued to spec. I going to order a new spacer when I order bearings and seals.My build thread --->http://www.tlplanet.com/forums/showthread.php?t=79793
Re: Not again!
Rob do you have the spacer between the two bearing and did you press the down to the seat ridge in the hub. There should be no space between the bearing and the spacer. Spacer should not move around ,If there is clearance at the spacer the bearing are not seated.T.L.Last edited by TerryLemmons; 09-20-2010, 01:56 AM.sigpic391 lbs or 177.34 kgLIST OF MODS ,The Short List ,The frame Is Stock.
Re: Not again!
The spacer is fooked up. Both ends gouged up by a previous owner and I never thought that would affect the bearings. A new spacer is about $25 on cheapcycleparts.com.My build thread --->http://www.tlplanet.com/forums/showthread.php?t=79793
Re: Not again!
when you tighten the axle the center races of the bering get pushed inward , the outside races stay put. When you take out the old bearings out, look and see if there is more wear in on one side .get a new spacer .T.L.sigpic391 lbs or 177.34 kgLIST OF MODS ,The Short List ,The frame Is Stock.
Re: Not again!
Originally posted by plumber_rob View PostThe spacer is fooked up. Both ends gouged up by a previous owner and I never thought that would affect the bearings. A new spacer is about $25 on cheapcycleparts.com.
1996 Suzuki GSX-R750 FRONT WHEEL SPACER,FR HUB BEARIN View
1997 Suzuki GSX-R750 FRONT WHEEL SPACER,FR HUB BEARIN View
1997 Suzuki TL1000S FRONT WHEEL MODEL K1 SPACER,FR HUB B View
1997 Suzuki GSX-R600 FRONT WHEEL MODEL V W X SPACER,FR HUB B View
1997 Suzuki TL1000S FRONT WHEEL MODEL V W X Y SPACER,FR HUB B View
1997 Suzuki GSX-R600 FRONT WHEEL MODEL Y SPACER,FR HUB B View
1998 Suzuki GSX-R750 FRONT WHEEL SPACER,FR HUB BEARIN View
1998 Suzuki TL1000R FRONT WHEEL SPACER,FR HUB B View
1998 Suzuki TL1000S FRONT WHEEL MODEL K1 SPACER,FR HUB B View
1998 Suzuki GSX-R600 FRONT WHEEL MODEL V W X SPACER,FR HUB B View
1998 Suzuki TL1000S FRONT WHEEL MODEL V W X Y SPACER,FR HUB B View
1998 Suzuki GSX-R600 FRONT WHEEL MODEL Y SPACER,FR HUB B View
1999 Suzuki GSX-R750 FRONT WHEEL SPACER,FR HUB BEARIN View
1999 Suzuki TL1000R FRONT WHEEL SPACER,FR HUB B View
1999 Suzuki GSX1300R HAYABUSA FRONT WHEEL SPACER,FR HUB B View
1999 Suzuki TL1000S FRONT WHEEL MODEL K1 SPACER,FR HUB B View
1999 Suzuki GSX-R600 FRONT WHEEL MODEL V W X SPACER,FR HUB B View
1999 Suzuki TL1000S FRONT WHEEL MODEL V W X Y SPACER,FR HUB B View
1999 Suzuki GSX-R600 FRONT WHEEL MODEL Y SPACER,FR HUB B View
2000 Suzuki TL1000R FRONT WHEEL SPACER,FR HUB B View
2000 Suzuki GSX1300R HAYABUSA FRONT WHEEL SPACER, HUB BEARING View
2000 Suzuki TL1000S FRONT WHEEL MODEL K1 SPACER,FR HUB B View
2000 Suzuki GSX-R600 FRONT WHEEL MODEL V W X SPACER,FR HUB B View
2000 Suzuki TL1000S FRONT WHEEL MODEL V W X Y SPACER,FR HUB B View
2000 Suzuki GSX-R600 FRONT WHEEL MODEL Y SPACER,FR HUB B View
2001 Suzuki TL1000R FRONT WHEEL SPACER,FR HUB B View
2001 Suzuki GSX1300R HAYABUSA FRONT WHEEL SPACER,FR HUB B View
2001 Suzuki TL1000S FRONT WHEEL MODEL K1 SPACER,FR HUB B View
2001 Suzuki TL1000S FRONT WHEEL MODEL V W X Y SPACER,FR HUB B View
2002 Suzuki GSX1300RZ HAYABUSA FRONT WHEEL SPACER,FR HUB B View
2002 Suzuki TL1000R FRONT WHEEL SPACER,FR HUB B View
2003 Suzuki GSX1300RZ HAYABUSA FRONT WHEEL SPACER,FR HUB B View
2003 Suzuki GSX1300R HAYABUSA FRONT WHEEL SPACER,FR HUB B View
2003 Suzuki TL1000R FRONT WHEEL SPACER,FR HUB B View
2004 Suzuki GSX1300RZ HAYABUSA FRONT WHEEL SPACER,FR HUB B View
2004 Suzuki GSX1300R HAYABUSA FRONT WHEEL SPACER,FR HUB B View
2005 Suzuki GSX1300R HAYABUSA FRONT WHEEL SPACER,FR HUB B View
2006 Suzuki GSX1300R,Z FRONT WHEEL SPACER, HUB BEARING View
2007 Suzuki GSX1300R,Z FRONT WHEEL SPACER, HUB BEARING View"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Re: Not again!
I have ordered from both sites in the past and cheapcycleparts was faster. Shipping time was a week compared to two - three weeks from ronayers.My build thread --->http://www.tlplanet.com/forums/showthread.php?t=79793
Re: Not again!
My new seals, bearings, and spacer came in today. The old spacer measured 105.60 mm and the new one measured 106.6 mm. The old one looks like the axle must have been over tighten in the past crushing the ends of the spacer. Plus there was some nicks and scratches and it wouldn't slider over the axle without some force behind it.My build thread --->http://www.tlplanet.com/forums/showthread.php?t=79793
Re: Not again!
Pics of the new and old spacer and old bearings.
New on the left, old on the right.
Old bearings. Can you guess which one went bad.
quite simply by overtightening it. It's only alloy, a decent rattle gun in the hands of a numpty will fuck things quick smart.
check the bearings for grease Rob. I never relie on the factory stuff in there, even been supplied new bearings which had no grease in themI always clean the factory crap out and repack with a good quality product - at least I know it's done right then and never have to worry about it.
That goes for any bearings I buy, fishing reels, lawnmower wheels, kid's scooter etc.
