Forks?.....
  • Forks?.....
    Hi all, this winter i'm gonna be taking my bike apart and spend a little time and money on her..as i bought her in may and not have the time to really get into it, though did get to france on her for the weekend-electrics played up and had to keep bumping her which is all part of the fun!
    i want to clean up my front end (stone chips and just not been looked after really)
    i don't mind how it handles-ish. coming from a zx7r which was so well planted!
    i have limited money-as we all do? so do i get the forks cleaned up..nitride coated maybe etc..
    ...or look for a cleaner different set?
    What to do!?
    Thats the great thing about forums, for the 10% of useful information you have to have the 90% of shit that goes with it...
    Re: Forks?.....
    The busa swap was easy and I like the results added a wee bit of gold bling as well
    If all else fails WD40 and a hammer
      Re: Forks?.....
      do busa forks fit straight on, and apart from bling are they any better than the tls standard forks?
      how much is nitride coating?
      if its not broken MOD it
        Re: Forks?.....
        What year busa and other than the forks what else do you need?
          Re: Forks?.....
          Any year Busa forks are a straight swap until they went radial in 2008.
          If you want really good brakes aswell then consider the GSXR Radial forks and calipers, I do various fitting kits depending on what year/combination of calipers you go for.
          It's worth noting that you still use the 320mm TL discs as opposed to the 298/310mm discs of the GSXR's hence why the brakes are soooo good
            Re: Forks?.....
            Hi Sam,I have a 1999 tlr and want to upgrade front end forks/calipers etc,whithout to much hassle ie direct bolt on,Do you supply kits etc and if so could you email with price etc?
            Regards
            Keith.
            [email protected]
              Re: Forks?.....
              The gsxr route is the way forward
              TL1000SV(97),1040 bore kit,suz 21 cams.radiusd inlets,full 57mm system.pc111.k & n,+ mod,charging mod,gsxr radial front end..tlr swingarm,ride height adjuster,ohlins rear damper..
