can a mph speedo be changed to a km/ph
  • can a mph speedo be changed to a km/ph
    whats involved, can the reading be changed electonically and i guess the faceplate needs changing, can that be done
    thanks
    Re: can a mph speedo be changed to a km/ph
    no...
    the faceplate is simple but the odometer is not
      Some of the speedo recalibrators will do the conversion that do the odo and speedo without changing the face plate.
      But that way affects the indicated top speed. 300mph on metric dials and 185km/h on imperial speeds
      I'm pretty sure the recalibrator sticka is using does conversion both ways. Not 100% sure though.
      Like Stu said, changing the face plate does the speedo but not the odo, and the temperature would be the opposite too. (Fahrenheit vs. Celsius )
        i forgot about the temp grrrrrrrr, i was hoping the speedo had capabilaties of switching between miles and kays like the modern gixxers.
        oh well
        does anyone have a tlr speedo showing around 18-20,000 kays?
          There is an american mob that re-sets odometers
          try google.
            Bluegauges I think the mob is.
              http://www.bluegauges.com/
                It's been a while since I sold my bike but I do believe the SpeedoHealer I had on it offered the ability to switch between mph and kph without the need to change the speedo faceplate. You can also use it to correct the speedometer's calibration which is off right from the factory.
                  Originally posted by Steve TLS View Post
                  i have just emailed these guys, thanks for the link
