tiller jugs
  • tiller jugs
    OK i know you all looked at this post because you thought it had something to do with tits,haha it doesnt my friend pulled down his tiller and do a top end and one of the cyclinders is badly scored and we DONT think honing will remove it,my question is....... do you replace the hole jug I cant see where there is a sleve like I 4's Has anyone done this before and could shead some light on it thanks guys TM
    From what I have read the cylinders are coated with Nickelsil, a silicone nickel compund that is applied with electrical current. Might have to get it redone if honing doesn't take it out.
      Whoops, no tits here. Next!
          The bad news is, you can't hone Nickasil. Personally, I'd like to find a good place that will re-line 'em.
          Kim
          CCS AM #507
          Twilight Racing
            rrrrrrrrrrrrrr
            so is what your saying is .............. my friends is fucked The bike ran good it just had aintifreeze on top of the valves,so we pulled the moter and pulled the top end off.Have you ever heard of that?
              Duuuuuuude - Poor choice in Thread Names
              I'm with ya WT !!!!
              "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming WOW, what a RIDE!!"
                you suck
                MY MODS:
                TO BE CONTINUED
                  you bastard
                    Re: rrrrrrrrrrrrrr
                    Sounds like a head gasket problem allowed coolant into the cyclinder and damaged the bore.
                    I think LA Sleeve does two stroke Nikasil cylinders, bought I'm not positive. You may be able to get it replated.
                    Just thought of another. I think it's millenium technologies
                    worth a look anyway
                      rrrrrrrrrrrr
                      thanks guys
                        Give these boys a call
                        Millennium Technologies provides repair and maintenance services for cylinders and cylinder heads, and manufactures nickel silicon carbide plated cylinders for a variety of engines, including motorcycles, snowmobiles, race cars, karts, dirt bikes and watercraft.
                        Of course it's probably cheaper to find a used cylinder somewhere.
                          Here's T's for yah (0)(0)
                            t's
                            EVERYONE love a nice set of tits even women ....(0)(0)
                              He might sell that for cheap if he still has it. Split and rebuild.
