First of all, I have the early really smooth sine-wave-like original Braking Wave rotors (nice and flat with plenty of thickness, and bought used). What are they made of? They're not rusting so far whereas cast iron may have, so are they stainless? Some pads can't be used with cast iron, others are recommended to be used with cast iron.
There don't seem to be good independent test results easily available for motorcycle brake pads from different mfgrs.
I had good results in 1997 on my old TLS with Ferodo pads on transplanted TLR 6-pots so I'm looking at Ferodo again, instead of Carbon Lorraine (new kids on the block??).
Ferodo has more than 12 different pads for the TLR brakes. 6 compounds in two different pad thicknesses. Forget the organics. Their track day sintergrip ST/STAc pads sound good, but they're phasing them out. Sintergrip SG seem to have about the same specs. I can't find good info about the difference between Comptition 211 versus competition 111. Looks like the SinterGrip XRAC may really chew up discs. Looks like anything with Competition in the name doesn't work wet and is really noisy too.
I'm inclined to try the Competition 211. Then there's some options for whether they have holes in the friction material (for cooling and de-gassing). In some pad materials the "feel" is better with the thinner pads because they don't compress as much, but for the street I'm inclined to get the thicker pads, which should still have good feel with a very metallic compound.
Anyone have any real expereince?
