any suggestions would be helpfull
front brake rotors??
Re: front brake rotors??
Originally posted by dstlr View Posti need to replace the front brake rotors on a 97 tls, will rotors from a gsxr,hayabusa,sv fit on a tls? i am running stock caipers and ebc pads
Originally posted by twin2 View PostI believe the busa Motor is bigger, but if Mikey says it's not who am I to dissagre
Any 91 mm PCD 320 mm diameter rotor will bolt up,only difference is they went to a 8 button mount (carrier to disc)
That means Hayabusa to 07.
GSXR 600 / 750 / 1000 until the diameter was reduced and in the case of the 600 rotor the disc is thinner.
Any TL1000R.
Front brake rotors.
This is a TL1000S rotor...10 buttons..It is the same as the SRAD GSXR rotor
because it is a SRAD rotor dating from 1996.
Here is a Hayabusa rotor to 2007 (8 button,same as the TLR rotor but a different colour/color carrier is all.
Same as GSXR1000 to 2002.
Any 320mm / 91mm PCD for the fasteners flat carrier Suzuki rotor will interchange between bikes that came with them as standard.. SRAD GSXR..TLS..TLR..Hayabusa...2001/2002 GSXR1000...GSXR600's also but the rotor is thinner IIRC.
The only basic difference is the number of buttons and carrier colour..Silver/Gold/Black.
The newest OEM rotors used in the best condition are on a 2007 Hayabusa ?.
Trivia.
Before the flat carrier rotor was the dished 310 mm found on quite a few Suzuki's including the GSXR pre SRAD 750 and 1100's back to around 1988.
It looks to be the same rotor used on some Bandit's and GS500's later on.
Will not fit the TL.
The GSXR's went to a different wheel and rotor in 2005 on the 1000's,a year or so later on the smaller GSXR's and the Hayabusa got them in 2008 with the same wheel but wider at the hub.
310 mm and a much bigger PCD (diameter where the bolts fix it to the wheel hub)
