Anyone have any ideas? is there a way to relocate the thermostat so it reacts quicker? Im desperate please help!
TLR overheats quick in traffic HELP!!
I have a manual fan switch and even with it on my bike gets real hot real quick. It seems like by the time the thermostat opens the temp has already jumped 10-15 degrees. It does fine as long as Im moving the whole time. I have my headers wrapped.
Anyone have any ideas? is there a way to relocate the thermostat so it reacts quicker? Im desperate please help!Tags: None
Re: TLR overheats quick in traffic HELP!!
What temp is displayed on the dash that you consider "overheating"?
Do you have enough coolant in it? Trapped air in the system? Is the water pump working as it should? Are the radiator hoses reletively cool compared to the engine temp?
Let's see, what else can you test for without stripping it down.....?January 2012 - BBOTM & TLOTM
Originally posted by Sticka View PostWhat temp is displayed on the dash that you consider "overheating"?.
what makes you think it's "overheating"
When was the system last maintainedRead the manual, time to learn something.
Assuming things are wrong without all the facts is a waste of time. I think your worrying too much.
The fans don't normally come on until about 106C / 223F or so.
The dash will warn you that it is overheating at 120C / 248F. And you should shut it down - or start moving.
If you ignore that. it has another warning at 140C / 284F.
(But the ECU will never shut the engine down to over temperature)."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
On top of the normal trouble shooting of plugged radiator tubes and thermostat functionality, or lean or rich air/fuel ratio, some of these suggestions may help. Do keep in mind that TL's normally run hot when sitting.
What coolant and percentage are you using?
Engine Ice and Water Wetter are the preferred choice for TL's.
What is the ambient temp that you riding in?
The manual fan switch is a common mod. Also swapping the automatic fan switch to one of the following will turn the fans on at a lower temp.
Geo Metro fan switch:
SUZUKI : 17680 50 F10
ECHLIN : FS154
AC DELCO : A1854
STANDARD : TS306
4 SEASONS : 36567
WELLS : SW1888
Muzzy used to make an aluminum fan blade to replace the factory plastic. There's not much feedback as to it's success, but tracking one down may help. Part# HT-H1.You do not talk about Fight Club....
ECHLIN : FS154
AC DELCO : A1854
STANDARD : TS306
4 SEASONS : 36567
WELLS : SW1888
Originally posted by Six5 View PostThis is a handy list Suprachrgd82. Do these have the same thread diameter and pitch? And will the TL's connector fit them?
she will overheat if you are sitting still on a 90'F day with the engine idleing. the TL is a heat monster, all there is too it.
the manual fan switch mod really REALLY helps. when you see some "sitting still time" comming, flip it on. I can keep the bike under 200'F if i'm not just sitting still for an hour.
Really helps
How do I install my 1/5th throttle insert? Just click me for the install thread... Or click here for the .pdf updated version.
Silver metalic flake Clear Clutch cover has been sold See what was available here. (8/12/09)
