Ever drag your kickstand?
I went for a nice ride with some friends in the canyons a few days ago. As I was taking a tight uphill left corner, I heard the sound of scraping metel. I got home and had a look at my bike and sure enough I scraped up the kickstand and my exhaust. I had the bike leaned over pretty good, but I'm thinking maybe my suspension is too soft or has this happened to anyone else?Tags: None
Re: Ever drag your kickstand?
No,I haven't.
Sounds like the rear end might be a bit low-have you set your sag?Full Yosh
PC III
Penske shock
Braided lines
SteveTLS TRE
Rifleman 1/5
Pazzo levers
Vandriver tailrisers
Modified Buell footpegs
Custom Projector headlights
GSXR forks
TheRingin raised clipons
Ohlins steering damper
GSXR mirrors
TLOTM Sept 2011
BBOTM Nov 2011
do it all the time.
2 up with Reet on the backwww.cycleinnovations.com.au
I had that problem on track and consequently removed the kickstand. Didn't help, I still dragged midpipes, so I raised the rear about 0.5 to 1cm. Didn't help for long, with a good rear tyre I managed to drag the shift arm, the footpeg and the midpipeI then went for shorter footpegs, but still managed to drag them.
Note that I did NOT crash.
But honestly on the road... it shouldn't happen! You should either drive more careful or raise the rear.
Greetings
RuferLast edited by rufer; 10-08-2010, 06:59 AM.TL1000SW, candy jade lime yellow. TL1000cup.de champion 2007, 2008, 2009
Originally posted by Spyrious View PostYou guys must be going very fast to lean the bike that far.
Stu, a US stand
http://wotid.com/pictures/thumbnails.php?album=45
A photochop of the two on the bike: (I was after more ground clearance due to the M4 holding the stand down a touch).
Last edited by Steve TLS; 10-08-2010, 07:44 AM."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
no I just lean over a long way.
dont hang off at all.
no chicken strips when I ride solo
5 mm two up.www.cycleinnovations.com.au
I think I will check the sag today. When I got the bike, I set the suspension to standard settings and it felt pretty good to me. But this last occurance I was wearing full leathers so the weight probably made a difference plus pushing it a little hard. Ha Rufer, now my exhaust looks like yours!
