Bike cutting out at half throttle while riding
When my bike gets up to normal running temperature and I'm cruising at a normal speed and I go to roll on the throttle more than half way, it completely shuts down and almost throws me off the front of the bike. As soon as I let off the throttle it goes back to driving normal. The fuel injection light has come on one time but I was unable to get an error code because it shut off. Ive also tried riding the bike with the gas cap open- its not a venting problem.Mods: Yoshimura full stainless system shortened 4", PCIII, TRE, K&N airfilter, air box mod, flush undertail, Lockhart Phillips windscreen, HID headlights, Billet shorty brake levers, hot chick on riders seat.Tags: None
Re: Bike cutting out at half throttle while riding
So, while it is running on the "cold" map it doesn't do it? It olny acts this way on the "warm" map?
Does it always happen at the same RPM?
Have you serviced the fuel filter lately?
Happens in any gear?January 2012 - BBOTM & TLOTM
It only happens when warmed up, mostly between the 4 and 7 thousand RPM range, haven't serviced the fuel filter, and it happens in every gear.Mods: Yoshimura full stainless system shortened 4", PCIII, TRE, K&N airfilter, air box mod, flush undertail, Lockhart Phillips windscreen, HID headlights, Billet shorty brake levers, hot chick on riders seat.
So, when it is "cold" it works fine. You can wind it up to any RPM and it does not stumble? Is this true? Bear with me, I'm just trying to get a clear picture. What do you consider "warmed up?" What temp does your gauge show?
When did this begin happening?
If it stumble like that at any temperature, it is very likely a fuel delivery problem. It would be worthwhile to verify your fuel pressure - when it is cold AND when it is warm.
Does your airbox still have the IACV flappers in it? Or has it been modified?
Try running it in the dealer mode so you can read any codes that may appear.
Still thinking......
Or, could it be related to the secondary injectors? Thinking out loud.....Last edited by Six5; 10-10-2010, 12:45 AM.January 2012 - BBOTM & TLOTM
It only does it after riding about 10 minutes and when it reaches 185 degrees or more. It seems to get worse the hotter it is. It has an airbox mod done to it. and it has done it intermittently for a long time but has gotten worse.Mods: Yoshimura full stainless system shortened 4", PCIII, TRE, K&N airfilter, air box mod, flush undertail, Lockhart Phillips windscreen, HID headlights, Billet shorty brake levers, hot chick on riders seat.
Originally posted by onebadtlbabe View Post..... It has an airbox mod done to it.
Originally posted by onebadtlbabe View Post..... and it has done it intermittently for a long time but has gotten worse.
I may be off base, but if it were mine, I would at least verify that the fuel rail is getting the pressure it needs. The manual says 41 psi. Once that is done you will know whether to pursue the fuel issue or look for possible electrical problems - like ignition coils and wires, flakey PCIII, etc.
That reminds me. Have you tried running it without the PCIII in the circuit?January 2012 - BBOTM & TLOTM
INJECTORS might also need cleaningbut also TPS can cause similar issues good luck...
age is a state of mind
sigpic[IMG]
Originally posted by CWBethel View PostINJECTORS might also need cleaningbut also TPS can cause similar issues good luck...
The TPS is another good place to look. You will need to test it per the service manual on pages 4-39 and 4-40. Make sure when you are watching the ohmmeter or the voltmeter as you SLOWLY turn the throttle that the readings likewise increase steadily and smoothly - no glitches or dead spots.
Might want to start with this test. It is less messy than checking the fuel pressure.January 2012 - BBOTM & TLOTM
I was having a similar problem. Coming out of left handers on the track the hike would try to spit me off (i am slower in left and get ham fisted to try and get sped back up for straights) I pulled the fuel pump and put a filter in it. The filter was clogged horribly, and that was my issue. The warmer the bike got the worse it got, and happened in between 6-9 k rpm in any gear. I came to the conclusion that with the filter clogged, the bike was running lean, and detonating causing my problem. The bike dropped about 4 deg f, once fixed too.
turns out it was the fuel filter in the fuel pump. It was clogged from a rusty gas tank.Mods: Yoshimura full stainless system shortened 4", PCIII, TRE, K&N airfilter, air box mod, flush undertail, Lockhart Phillips windscreen, HID headlights, Billet shorty brake levers, hot chick on riders seat.
