side mounted steerig dampers
is there anybody runing side mouned steering dampers on their TL's?MY BIKE: 1998 TLS 107.52 Hp 71 lb-ft.
http://www.tlplanet.com/forums/showthread.php?t=92328Tags: None
Re: side mounted steerig dampers
On my TLs I had the early very long Hyperpro mounted along the upper frame rail to a fancy clamp on the fork leg. It worked exceptionally well! The longer damper means there's less hydraulic play associated with actuating the Hyperpro velocity-sensitive valve. IMHO it was also stronger, able to handle more force. That's how most early dampers originally were mounted. Slightly heavier, installed wrong it might pinch your fingers or something. I put the damper's rod heim to the frame and the damper's body clamp to the fork so it was tucked in close to the frame and out of the way. On the TLS I even made a bracket around the frame that used some stock holes in the frame. With the carbon fiber wheels it worked VERY nicely, at low speeds it felt like no dmaper at all.
But now the problem is finding a damper as good in such a long length.It's about control skill; this is a motorized dance for joy and not Russian roulette.
i will have a hyperpro csc long steering damper soon, so i am thinking and trying to figure out how and where could i mount itotherwise i would need to sell it and get another one that fits with my top mount brackets that i bought a while back...
cyclecamper, do you have any photos of your setup? sounds like a great idea...MY BIKE: 1998 TLS 107.52 Hp 71 lb-ft.
i use a ohlinsmods:Joe V air box-smart tre-vans pressure plate/retainers,brake return spring,battery holder,oil cap,top triple-rifleman 1/5 insert&clutch cover-shorty levers-billet grips-screw off gas cap-yoshimura rear set bracket-folding foot controls-gap tray mod- custom gsxr tail section on moded subframe-gsxr forks and radial calipers-full Galfer lines-slash cut exhaust-4" packed baffles-chrome exhaust tips-norton headlight-custom overflow bottle-ohlins side mounted damper-carbon fiber tank guard.
Originally posted by Johnny Cizzle View Posti use a ohlinsIt's about control skill; this is a motorized dance for joy and not Russian roulette.
allmost all brands has side mounted type dampers, but that doesn't matter, what matters is how/where you can fix the damper ?MY BIKE: 1998 TLS 107.52 Hp 71 lb-ft.
Yes, I run side mounted on the 1040
M8 Steel Rivnut into the frame spar and a recessed spacer to spread the load onto the frame spar rather than just the head of the rivnut.
