press style master link tool?
Re: press style master link tool?
The only right way to do it is to use proper tool...U probably don't have tonight.
That is one of those things that should be done right the first time.
RK has a nice tool U can get from sprocketcenter or any other place on web
I have a soft link on mine, Its been on there since I bought the bike. But about 4 months ago, while sparky attempted to fit a larger sprocket on the rear wheel. We noticed the link had come off, on one of my last commuter rides.
We replaced the link.
And its still, on my list of jobs to do....
New wheels coming so it will be the excuse I need to change the chain.************************************************** **************************************************
My bike mod list - Click here
you could use a large pair of vise grips and a small ball bearing.
seat the side plate on the link to the right depth and adjust the vise grips to the right width . place a 1/8 ball in the cup on the end of the chain rivet and squeeze the grips . tighten the gripa a couple of times to spread the pin.
do both .
now get a 1/4 ball and repeat the exercise to flatten the end some more.www.cycleinnovations.com.au
If you buy one, I recommend the RK tool, priced around $100.00 but worth every penny. Once you have one, you can do other folks chains and your own. Every time you do a chain you save $80.00 or so, pays for itself quickly.Be Good, Wear Gear, Do Wheelies,
Doug "OldTLSDoug" Basinger
2006 Suzuki GSXR750
2007 Aprilia SXV 550
G-Town Squid Squad
Last time I used a grinder to get the links off, and a hammer and a drift (?) to make sure the rivet would never move of itself.. You use what you have at hand..
That's not the way to go, so next time I need to change the chain I intend get the right tool. But I'm sometimes confused with the different manufacturers - they seem to hint that you need their tool for their chain. But that isn't the case, right?/K0m4
so far:
Bitubo rear shock! Racetech fork internals, M4 full system, Matt's TRE, Rizoma grips, FP Racing folding levers, IPP cf screen, Van's ccc, plate, front & rear brake reservoir, & sprocket cover, Buell-busa peg mod (oooh my legs).
Soon to be:
IP Performance CF hugger, gap. Maybe a clear headlight with angel eyes?
Another RK user here. I love mine and have done dozens of chains with it. I always grind down the pins before using the tool to break the chain.- If you find this site useful kick us a few bucks. <a href="http://www.tlplanet.com/forums/billspaypal.php"><b><font color="blue">Tip cup</font></b></a>
Originally posted by cyclecamper View PostMine is not RK but looks identical to the picture. I think mine is from MotionPro, as is my chain breaker.
Darn it, this Krause chain is incredibly heavy-duty (and heavy). Sideplates are really thick, pins are really hard. I broke the motion-pro tool trying to spread the rivets a bit, and the ricets still don't look peened at all. It went together so tight it would probably never come apart even without peening. I'm afraid you could never rivet these with a ball bearing and vise-grips, they're just way too hard. I should put a large hard steel block behind the master and use a hard sharp large center-punch.It's about control skill; this is a motorized dance for joy and not Russian roulette.
