TL100S wont rev over 6500 revs
my TL1000 wont rev over 6500 rev's. I have changed the spark plugs and i put injector cleaner in my fuel tank, but still the same problem, i also checked the ECU diagnostics code and it shows c00 which is no fault. Any ideas??Tags: None
Re: TL100S wont rev over 6500 revs
Fuel filter or side stand switch.
Do the fuel pump test out of the manual. Measure how much fuel comes out of the return line / time. If it fails, it's probably the fuel filter.
Check that the side stand switch mounting bolts are tight and the stand is depressing the plunger all the way."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
What Steve said.
And welcome."The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."
what happens when it gets to 6500
is it only under load or will it not free rev in neutral also
is this a new problem or have you just bought the bike with it or what else.
the more info you can provide the more accurate the help can be.www.cycleinnovations.com.au
i checked the stand switch not that, gonna check the filter now.
it's fairly new, it got worse, used to do it at about 8500rpm and now recently got worse, my fuel consumption also dropped from about 260km per tank to about 170km per tank. I checked revivng it in nuetral seems fine, its only when i ride, when it reaches 6000 / 6500 it seems to stop and just go prprprprprprprprprprp until i change, sometimes when i just hold it at eg. 2500rpm when in nuetral it will idle and seem to dup and rev again like rrrrrrrrrrrrrrrrrrrrrrrrrr dup rrrrrrrrrrrrrrrrrrrrrrrrrrrrr dup rrrrrrrrrrrrrrrrrrrrr when i drive sometimes the bike also will ranmdomly jerk while riding between 3000 and 4000 rpm's.
might also check ignition leadsage is a state of mind
sigpic[IMG]
its the fuel filter, i stripped out the fuel filter and brown stuff started coming out out, had to blow real hard into it to get air out the other side, the spare shop was closed so i by-passed the filter for now will get one tommorow, its revs right through 9500revs now. thank you everybody !!!!!!!!!
You may seriously want to consider doing the external filter mod at this point in time .Triumph 1050 Speed Triple
TLS naked project
Rebuilt motor from Sam, 04-06 R1 forks/brakes and wheels, Penske shock and spring + Linderman link, Big bore zorst with Ti Scorpion cans, TLS that needs some loving .
Free reving isolates it from a computer problem.
well foundwww.cycleinnovations.com.au
I ditched the stock filter. I bypassed it and installed a glass inline filter I got at napa. It says not to use that filter with FI systems but I havent had any problems with it leaking. the glass cylinder is thick too so i doubt its going to burst or crack easily. Plus I can SEE when my filter is dirty and clean it out or buy a replacement filter element.1998 TLS
Lower fairing kit, +MOD, TRE, PCIII, D&D Full System, K&N, Airbox MOD, HIDS 8K, Gunmetal powdercoated rims, Atomic Orange paint.
So it says not to use it on a FI system and you used it anyway?I hope for your sake it doesn't burst under the FI pressure.
There would be a reason they say not to use their product on a fuel injected system."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Could be that you have a TL100. The 1000's usually rev a bit higher.
Jokes aside, good find on the filter. I've replaced mine but haven't opened the old one to see how clogged it was.Originally posted by Rifleman
...I'm more busy then a one legged man at a butt kickin' contest.
I had a similar problem also.... It would pull all the way to 6.5k-7k rpms and then fall flat on its face... come to find out there was a split in the rubber hose section inside the tank on the pump cradle. the rubber section between the filter and the pump.1998 TLS
