tl1000s clutch
Re: tl1000s clutch
you need the entire clutch inc springs cam mechanism etc less a pressure plate.www.cycleinnovations.com.au
Re: tl1000s clutch
It needs to be 100mm IIRC
I know mine was a little long when I finally left it and thought I couldn't be bothered taking any more off, and adjusting the clutch again.
Mine is at present 102.6mm and works fine, but the adjuster screw is wound right out.************************************************** **************************************************
My bike mod list - Click here
Re: tl1000s clutch
The 6-spring basket and hub will take the early 6-spring disc pack or the late-model 6-spring disc pack which has 2 more discs, which is what you want to use.
The clutch cam set is always the first thing to go on any TL clutch, so I recommend getting that set of parts new.It's about control skill; this is a motorized dance for joy and not Russian roulette.
