From what everyone says, the intake tracts on the TLS are a real choke point in the system and even running with no filter makes no difference to air pressure inside the airbox. It seems the intake tract just can't pressurise the inbox enough. So I wondered if anyone had attempted to get around the problem by doing the following:
Has someone ever made up larger intake tracts that instead of running below the chassis spars/rails, through the tunnel and up into the air cleaner like on the standard airbox, they ran straight back between the chassis spars/rails and into each side of it? It would require blocking off the bottom of the airbox and the use of individual air filters on the throttle bodies.
It seems to me that it would have been a more efficient way of getting pressurised air into the airbox a la Kawasaki's ram air system (which has been proven to work very well) , and the space to do it seems to be there.
Thanks for your input,
Harry
