Fuel pump PSI
Fuel pump PSI
my 99 TLR is riding a bit funny since i bought it in june. around 4k rpms and below it has the worst throttle response. sometimes its ok sometimes it is jumpy. so i checked the fuel pump pressure and it is only putting out 32 or so psi. so i pinched the return line to see if it could reach 41 psi, and it didn't move. looking back i think that the person told me to pinch the in line to the tank....not sure.. what next?Tags: None
Re: Fuel pump PSI
Originally posted by motofreak87 View Postmy 99 TLR is riding a bit funny since i bought it in june. around 4k rpms and below it has the worst throttle response. sometimes its ok sometimes it is jumpy. so i checked the fuel pump pressure and it is only putting out 32 or so psi. so i pinched the return line to see if it could reach 41 psi, and it didn't move. looking back i think that the person told me to pinch the in line to the tank....not sure.. what next?
Re: Fuel pump PSI
Other things could be causing your "throttle response" issues, but concerning your fuel pressue, you should be able to reach the 41psi by pinching the return line. If it won't go up to 41psi then you either have a weak pump, or a clogged filter, or something really smothering the pickup screen.
Once you get the fuel pressure up to where it should be, you can chase the throttle response problem, if it still exists.Last edited by Six5; 10-25-2010, 02:15 PM.January 2012 - BBOTM & TLOTM
Re: Fuel pump PSI
The fuel rail regulator keeps the rail pressure 41psi above TB pressure not atmospheric pressure. (Although pinchin the return line should cause te pressure to rise).
Check that fuel pump pressure during prime when the throttle body pressure (vacuum) = atmospheric. Or bypass everything and run the pump manually and check the pressure.
If you check the ouput pressure of the pump when it's not connected to the fuel rail it should be between 69-99psi IIRC
(You might have a split line in the tank too)."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Re: Fuel pump PSI
what do you mean the pump pressure during prime?? are you talking about when you turn the bike on and the pump comes on for a few seconds? when i turn it on it goes up to 20psi and that's it. and the fuel regulator keeps the rail pressure 41psi above TB pressure and not atmospheric pressure? im not sure what you mean by that.
Re: Fuel pump PSI
Originally posted by motofreak87 View Postwhat do you mean the pump pressure during prime?? are you talking about when you turn the bike on and the pump comes on for a few seconds? when i turn it on it goes up to 20psi and that's it. and the fuel regulator keeps the rail pressure 41psi above TB pressure and not atmospheric pressure? im not sure what you mean by that.
Also it could be a clogged filter, but the filter would be pretty clogged. But I would start there. Change the filter, and clean the pickup screen. Then check. Make sure you use a new gasket and not silicon.
Re: Fuel pump PSI
i already took the fuel pump out and checked the screen, isn't that the same as the filter? or are you talking about the in line filter. i thought that was just an aftermarket thing that the prior owner had put on there. the screen is a little dirty so i sprayed it out with choke carb cleaner. and i did the same with the in line filter a while ago when i thought that was the problem. i unbderstand what you mean with the pressure. when i hooked up the gauge to the line it read the same psi from closed throttle to full open.
Re: Fuel pump PSI
Originally posted by motofreak87 View Posti already took the fuel pump out and checked the screen, isn't that the same as the filter? or are you talking about the in line filter. i thought that was just an aftermarket thing that the prior owner had put on there. the screen is a little dirty so i sprayed it out with choke carb cleaner. and i did the same with the in line filter a while ago when i thought that was the problem. i unbderstand what you mean with the pressure. when i hooked up the gauge to the line it read the same psi from closed throttle to full open.
Re: Fuel pump PSI
is there anyway you or anyone can post a pic of this in tank filter? i think that mine may have been removed. that's just for curiosity sake. i think that i may just send mine off and see if that fixes everything. the other problem is that it doesn't start.. i can get it to start but i have to use starter fluid. could that be the same problem causing that? once i start it with starter fluid it will start up on its own for a while after it is warmed up. could something be wrong with the regulator? how can i check it if there might be?
Re: Fuel pump PSI
Originally posted by motofreak87 View Postis there anyway you or anyone can post a pic of this in tank filter? i think that mine may have been removed. that's just for curiosity sake. i think that i may just send mine off and see if that fixes everything. the other problem is that it doesn't start.. i can get it to start but i have to use starter fluid. could that be the same problem causing that? once i start it with starter fluid it will start up on its own for a while after it is warmed up. could something be wrong with the regulator? how can i check it if there might be?
