OEM steering Damper Mounts
  • OEM steering Damper Mounts
    Hi guys,
    Can someone post pictures of the spacers for the TLS Steering Damper. I have the Fiche diagrams of the mounts but am not sure whch to use. I believe the spacers are the same for all years.
    thanks
    Re: OEM steering Damper Mounts
    There are no spacers to my knowledge.
    the damper bolts to the triple (it is shouldered ) and to the bracket.
      Are there washers? I bolted it up but it hits the steering head bolt due to the curved (lingo) spacer in the damper.
        Really thin washers. Top and bottom of the rose joints.
        (The 97 had the one piece left side bracket, the 98 and later had the two piece one)
          97 one piece:
          This is how the later ones were:
            i just have a cover top and bottom over the ball joint at each end which are pretty knackered, but thats it, no other spacers. it does not hit anything.
            if its not broken MOD it
              Yep, done the fairing stay mod & just got the 2 thin washers on the damper.
              People I will not deal with: tl1000swill or tlrwill or crazywheelie or whatever it decides to call himself.
                Isn't there a spacer between the triple and the mount on the damper? There must be one!
                Barely visible here:
                Otherwise only the already mentioned "washers". 2 piece mount (98+)
                Greetings
                Rufer
                TL1000SW, candy jade lime yellow. TL1000cup.de champion 2007, 2008, 2009
                  Thanks Guys, I think I can work it out from the pics.
