Eastern Beaver H4 Headlight Kit
  • Eastern Beaver H4 Headlight Kit
    Hi guys, got this today & just some questions for those who have installed this kit.
    1.Did you use the coupler or the posi-lock connectors ?
    2. Where did you mount the relays ?
    Cheers,
    Mick.
    Full Yoshi system - JSD 3A TRE - Powerbronze DB - BMC Filter - Fan Switch Mod - Braided Lines w/ EBC HH pads - Flushmount rears - Headlight Relay Mod - TLR Stackers Sliders
    Re: Eastern Beaver H4 Headlight Kit
    one ring terminal to the fairing bumper for ground, the other to positive on the battery. relays i tucked under the tray under the headlight housing. SOOO easy to install and very much worth it! my PIAAs were much brighter post wiring kit.
      For the TLR do we need the single or dual H4 kit? He has so many options it gets confusing.
      I just got the R/R kit, man what a nice setup. The quality is great.
      SK CF windscreen, Coerce CF fender, Pazzo shorties, Venom CF cans, Tech G rearsets, mesh inserts, integrated mirrors, gap mod, RatedR black fairing bolt kit, generic undertail, Rifleman's CCC, Complete set of Van's reservoirs, FH010 R/R Swap, Bitubo rear shock, Racetech fork springs, Galfer brake lines
        the dual - one for each head lamp ya muppet
          Originally posted by Patch11 View Post
          ya muppet
          Definition please. You have to clarify so i can laugh as well
          Thanks
          rookie
            Thanks
            rookie
            You have to understand Patch that being American,English isn't his first language
            Full Yosh
            PC III
            Penske shock
            Braided lines
            SteveTLS TRE
            Rifleman 1/5
            Pazzo levers
            Vandriver tailrisers
            Modified Buell footpegs
            Custom Projector headlights
            GSXR forks
            TheRingin raised clipons
            Ohlins steering damper
            GSXR mirrors
            TLOTM Sept 2011
            BBOTM Nov 2011
              Although,muppets are an American invention aren't they
              Full Yosh
              PC III
              Penske shock
              Braided lines
              SteveTLS TRE
              Rifleman 1/5
              Pazzo levers
              GSXR forks
              GSXR mirrors
              TLOTM Sept 2011
              BBOTM Nov 2011
                Muppet: Dick bag, fuckhead, retarded-foreskin sucking ass-wipe...etc...
                just playin' again fella's
                  Thats what i thought
                    version of Wikipedia.
                    Thanks to my f*cked up little black heart
                        Oops
                          Thanks, pillock.....jackanape...take your pick.
                          I speak the Queen's English......I learn everything I need to know from Top Gear.
                          Honestly I was confused because the instructions on the site said this...
                          Plug the H4 Coupler from the kit into the bike's H4 Socket you just pulled off the bulb. If you have H4 Dual headlights, you will plug the H4 Coupler into only one of the bike's H4 Sockets. The other will not be used so tape and tie-wrap it up out of the way. Make sure you insulate all old H4 Sockets as on the H4 Cautions Page.
                          So what the hell does that mean?
                            That means you only need to plug one of the OEM H4 plugs into the Eastern Beaver harness so it receives the correct turn-on/switch from lows-to-brights signal
                            I encountered the same dilemma with my Evil Eye wiring harness, much akin to the Eastern Beaver harness.
                              So his kits only have one H4 coupler for dual h4 setups? So why is there a special kit for duals? The picture looks like 1 H4 coupler and 2 sockets. Ugh. I'm too stupid for this shit.
                              Ok I got it. The kit replaces the two stock plugs and then you plug the coupler into one of the unused stock plugs?
