Whats this do, anyway ??
  • Whats this do, anyway ??
    Re: Whats this do, anyway ??
    lockin tab for the headstock
    it fits on top of the tank mounts were it bolts by the headstock
      It's one of those things because lawyers stick their noses into everything.
      IF Your head bearings would come loose and U had a wipeout without that piece in You could go after Suzuki...
          so it's one of those things I could dispense with like a steering damper, right?
            I left the bearing lock in place... and I left my stock damper in place...
            Its your decision.
            Mine was that I kept both.
              Freddie Gruger lost one of them, his little finger fell off
              if its not broken MOD it
                Only a lawyer is silly enough to think it could actually come loose together with both top yoke pinch bolts and steering stem nut, all without the rider noticing Oh, and the two collar thingies on the steering stem just under the top yoke..
                  ! So those fingers are not suppose to be locked into the slots in the headset bearing are they ?
                  Mine aren't even really touching, is this the norm ?
                    It keeps the bearing nut torqued, It can't come off but it can loosen. Yes, once it is adjusted, one of the finger thingies should get pushed down into the stem slot nearest to.
                      Well there you go > very enlightning .... thanx guys !
                          My damper is on and stock. I'd never take it off. The little finger thingy was never on my bike (bike bought used and in questionable conditions). So if it a must, I'll look for a replacement, otherwise, if it is a torque to specs thing, I'll most likely do so and take my chances
                          Afterthought: sucks getting second hand stuff that was touched by third rate hands.
                            mine never had one,and never had any issues,got one now though as sparky had a spare and put it on,my damper has been off the last 8yrs.that aint bothered me either.
                            Torque is cheap unless you ride a tl
                              Its hardly gonna throw YOU off is it Ian?
                              My bike mod list - Click here
