ghost would be proud
  • ghost would be proud
    I've ben working on my wheels every night when I get home. I've ben sanding my 12 year old probably never cleaned wheels and polishing the lips. Looks SWEEEEEEET!!!!!!!!!!!! When I get my pc fixed ill post pics when I'm done with painting the bike. She'll look sick!!!!!!!!!
    Re: ghost would be proud
    Can't wait to see the before and afters.
      They maid my stomach turn every time I looked at them.
        I'm glad I'm the resident "expert" on all things clean...
          Probably gonna look something like this...
            On Bike...
              On Bike...
              Yes, yes, I'm aware of the excess chain lube. Never too much right? Cleanup is always gonna be a bitch...
                what are you using to sand them? what grit and are you using steel wool also? Very nice?
                  Wet sand 400 to get most off then 1000g. Then polish with whatever brand you like. I used mothers and a sock. They look very good. Look in other wheel polishing thread supercharged was a lot of help. He had a very good recommendation for polish but I can't get it locale.
                    [ATTACH]23478[/ATTACH]
                    Yes but they won't be black.
                    Cobalt blue or yellow.?
                    I'm going to paint the bike cobalt blue and yellow.
                      Aircraft remover is a good solvent to get the paint lifted of the metal without using abrasives also. Just another option...
                        What ever grit you use,sand across the wheel outer lip first so you knock the machining marks down.
                        Harder to do but the best surface finish which lasts longer and is easier to maintain...fwiw.
