Power Commander
  • Power Commander
    Hi all I have an 02 TLR with a full yoshimura system and was wandering if I had to have a power commander it seems to be running plenty rich as there is alot of soot in the exhaust it is my understanding that for the most part the commander just richens the fuel mixture so is it really neccesary on my bike? Thanks for any input
    Re: Power Commander
    A PowerCommander can lean out the mixture too, but most use them to enrichen the mixture to suit exhaust and airbox changes etc.
    For it to be running rich stock, there is something not quite right there.
      Re: Power Commander
      If you are questioning your tune, take a dyno run and check the A/F ratio, it might be running closer to 13.5 than you think !
        Re: Power Commander
        Thanks for the input guys it is getting cold here in St. Louis so this issue may go on the backburner till spring
          Re: Power Commander
          injectors could be dribbly
          get them professionally cleaned over winter before you do any other changes
