Where Can I Find TLS OEM Rear Grab Handle?
  • Where Can I Find TLS OEM Rear Grab Handle?
    Where can I find an OEM rear TL-S grab handle like the one in this blurry photo?
    Thanks
    Dan
    Chicago/IL/USA
    Re: Where Can I Find TLS OEM Rear Grab Handle?
    A couple more images of what I'm looking for:
    Dan
      I can find one in my garage.
      You must be fast, 'cuz I was haulin' ass when I passed you.
          how about lookin here
          http://cgi.ebay.com/ebaymotors/SUZUK...Q5fAccessories
          http://www.cheapcycleparts.com/model...emblies/127757
            Originally posted by gaztl1000r View Post
            Better not pass that one up. They are hard to find and $30 is a steal. I thought about buying it and doubling my money.
              bit of a bargain , no point havin one on mine, can't take anyone on it, got no footrests,
              just how i like it
                Fabulous. I nabbed it. Thanks guys.
                Dan
                Chicago/IL/USA
                2000 TL-S
                  make sure it comes with the rubbers, spacers and bolts too.
                  My bike mod list - Click here
                    The eBay listing doesn't mention the attachment hardware. The item is used. If it arrives without these pieces...where could I get them?
                    Dan
                    Chicago/IL/USA
                    2000 TL1000S
                      you can cut the rubbers yourself and if you ask nicely I'll measure the spacers and you can have them made.
                      or get me to make them.
                        There ya go... !! Good on ya Stu.
                        I think I've asked that seller before about the hardware, and it doesn't come with it.
                          if the holes are not there already u need to disassemble the tail a bit so you can reach under and run a 6.5mm drill thru the subframe and out thru the plastics.
                          this gets the hole in the right place.
                          you then open it with an 8mm and put a bolt thru the hole and screw it in a bit.
                          you put the spacer over the bolt and scribe around it. this gives you the correct size and location of the actual hole needed. ease it out with a dremel or similar and bingo its done.
                            Stu, don't all the Subframes come ready for for the handle? I thought you just needed to drill the plastics?
                              they do you run the drill thru the threaded hole .
