sv 1000 coils
  • sv 1000 coils
    How much do they help? Do you need to change the plug wires or can you use the sv ?
    Re: sv 1000 coils
    They are hotter coils. So they help burn fuel better, which in turn helps to resist fouling of the plugs. You use the sv coil assembly. Wires, plug caps and all.
      Re: sv 1000 coils
      I picked up SV650 coils. The leads are longer, more flexible and fit on the plugs. But do leave a gap in the plug hole. Not a big deal, I'm sure they will stay on. Would the 650's coils be the same as the 1000's coils?
        Re: sv 1000 coils
        Don't think they are the same. But a cross reference on Ron ayers would verify.
          Re: sv 1000 coils
          sv1000 fit better then tlr and have no gaps anywhere.
          they are physically smaller so only one mounting hole is used, they are about a whole ohm hotter,
          get the newest available so they will last the longest, good improvement
