Need O2 bung
  • Need O2 bung
    Where in the USA can I get two stainless weld-on threaded bungs for mounting sensors for monitoring mixture? Where exactly should I weld them on without interfering with the radiators. bodywork, etc. (I've never had my TLR complete enough to tell).
    Re: Need O2 bung
    wait till i get home and I will post pics of where mine are.
    But you can get the parts from... www.frsport.com
      Re: Need O2 bung
      any auto muffler shop should have them
        Re: Need O2 bung
        Unfortunately, the ones local to me had mild steel but not stainless.
          Re: Need O2 bung
            Re: Need O2 bung
            Burn's Stainless
              Re: Need O2 bung
              Originally posted by vandriver View Post
              Burn's Stainless
                Re: Need O2 bung
                EXCELLENT! Thanks! Price is somewhat typical, bung and plug are stainless, and they take American Express! I ordered two right away!
                  Re: Need O2 bung
                  http://www.burnsstainless.com/
                    Re: Need O2 bung
                    Cool. Sorry didn't realize it was a company.
                      Re: Need O2 bung
                      I did a bit of research on this a couple of years ago, & the best place to put them is about 300mm down from the outlet port .
                        Re: Need O2 bung
                        Correct, o2 sensors are most accurate and happiest at 18 inches from the head. Unfortunately with the yosh exhaust it doesn't work that way. The front on mine is about 18", the rear is maybe 3 at most. I have another o2 sensor bung below the swingarm, but when we pulled it on the dyno there was too much mixing due to the crossover tubes. It was just too close to them. And since I won't be running o2 sensors all the time, the rear one can be that close for a short time.
