Vacuum Control Solenoid Valve-Important?
  • Vacuum Control Solenoid Valve-Important?
    While trying to set my TPS today, I broke the lower nipple off of the VCSV. So now, the hose is just dangling and there is a hole in the bottom of the VCSV. What is going to happen when I ride it? It won't blow up or anything will it?
    Custom Black with Multi-Color Metalflake 2000 TLR with Bitubo Rear Shock, Attack Rear Sets, Galfer Steel Braided Brake and Clutch Lines, BT-014 180 Rear Tire, TRE, PCII, BMC Air Filter, Yosh Stainless Full System, Joe V's Air Box Modification, Fan Switch Modification, Galfer Rear Wave Rotor, Hayabusa Gold Brake Calipers-Front and Rear, GSXR1000 Gauge, Daytona Temperature Gauge, CATS H.I.D. Headlights, No Cut Frame Sliders, Two Sided Fairing Stay, Extreme Graphics Undertail with Integrated Turn Signals, Polished Frame, Swingarm, Forks, Subframe, Steering Damper, Chrome Rims, Clear Clutch Cover, Gold Powdercoat on Triple Clamp, Clipons, Brake and Clutch Levers, Fairing Stay, Steering Damper Mounts, Rearsets, Passenger Pegs, Kick Stand, Calipers and Rotors, Hammerit Double Bubble Smoke Windscreen, Corbin Seat.
    Block the hose off with a golf tee or something. If it's the valve I'm thinking of, you airbox flappers wil just permanently remain open.
      Should I replace the part or just live with the .01 added weight of the golf tee?
        Do the Joe V mod to the airbox and you wont need it ever again
