I changed to two teeth up on my YZF600 and have that problem with the stock chain length so I know I should lengthen the chain on the TLR .
Chain Length-TLR this time
I am going to go to a 41 tooth rear sprocket. How long should my chain be so my axle bolt will not be all the way forward?
I changed to two teeth up on my YZF600 and have that problem with the stock chain length so I know I should lengthen the chain on the TLR .Custom Black with Multi-Color Metalflake 2000 TLR with Bitubo Rear Shock, Attack Rear Sets, Galfer Steel Braided Brake and Clutch Lines, BT-014 180 Rear Tire, TRE, PCII, BMC Air Filter, Yosh Stainless Full System, Joe V's Air Box Modification, Fan Switch Modification, Galfer Rear Wave Rotor, Hayabusa Gold Brake Calipers-Front and Rear, GSXR1000 Gauge, Daytona Temperature Gauge, CATS H.I.D. Headlights, No Cut Frame Sliders, Two Sided Fairing Stay, Extreme Graphics Undertail with Integrated Turn Signals, Polished Frame, Swingarm, Forks, Subframe, Steering Damper, Chrome Rims, Clear Clutch Cover, Gold Powdercoat on Triple Clamp, Clipons, Brake and Clutch Levers, Fairing Stay, Steering Damper Mounts, Rearsets, Passenger Pegs, Kick Stand, Calipers and Rotors, Hammerit Double Bubble Smoke Windscreen, Corbin Seat.
Answer given: I'm a member of T.L.C.! (The Loop Club) 5/23/04Tags: None
rick, i put a 41 tooth on a while back and was able to use the stock chain (i only had 3k miles on it). just put the chain on the sprocket before you put the rear axle all the way into the swingarm on the sprocket side (tilt the wheel).2002 TLR B/W. Yoshimura bolt on Titanium cans. Yosh box remap. Joe V airbox mod. plug in TRE. 17/41 sprockets. Zero Gravity double bubble screen.
