polishing stock TLS header /warning pics inside
Looks good, now just work your way down with the grit to really fine and they'll be polished for ah, 1 hr at most and they'll be golden brown!!!! Enjoy all your hard work cause in about ten min., the nice polish will be gone!
The only reason I'm so bitter, if you can't tell, is because I did mine 90% by hand and it turned the goldenish brown I referred to earlier!
Good luck!!!
rust?
no, the heat changes the color of the metal. My SV did the same thing when I swapped on a full system2000 TLS, bahama blue with guard rail mods, ProTek rearsets, Yosh Slipons, PCIII
2001 DRZ 400E M4 full system, Nstyle graphics, 320mm front rotor/17inch spoked rims on the way. Damn shipping
looks good so far. if you polish them with Mothers all purpose metal cleaner after every ride you can avoid the heat discoloration quite a bit. i've kept after the stock mid pipe section of my exhaust and they are still very shiny and don't have that golden brown tint to them.2002 TLR B/W. Yoshimura bolt on Titanium cans. Yosh box remap. Joe V airbox mod. plug in TRE. 17/41 sprockets. Zero Gravity double bubble screen.
