Service manual
  • Service manual
    Hi TL-friends..
    I'am working on a small projekt and have need for the pin assignment on the ECU on my TL1000R, meaning the lits with signal names and pin numbers or the whole electrical schematic would be even better.
    In worst case the signals assosiated with the GPS sensor would do.
    Anyone?
    Many thanks in advance.
    Twins are twice as fun
    wELCOME
      Welcome
      Just a few mods:
        mmm.. thanks?
        But why the finger folks? Just wanted to have a pinout for the ECU - i'am not trying to make people angry
        Roll on..
          Welcome, it's the Planet way of welcoming someone! Don't take offence.
          Sending a diagram via email now!
            Ooops, sorry, I don't have the TLR wiring diagram scanned. Someone will help you out.
              Ahh, who could guess
              THANKS! Great! Really thankful for that...
              Ok - everyone to you to!
                Ok, i guess it would be to much to ask but the pinout numbering signal names would do
                Or even better anyone with the service manual and a scanner
                I'am suprised i couldn't find more information on the ECU/ECM on the web. Anyone who knows any page with general information on the ECU?
                Roll on...
                  Welcome!
                  Steve, Doesn't superdodge have all the manuals hosted?
                    Originally posted by TLSBill
                    Welcome!
                    Looked at his homepage but it's not online now. Or you are maby reffering to another page?
                      I thought he had it on FTP?
                        Big Rig Nig has them too, but has a 50 post limit so only regulars can grab them.
                        It's a pink wire! I have all the TLS stuff here, but only bits and pieces of TLR stuff.
                        From the GPS, the black/white is an earth. The blue is the neutral indicator and the red is the GPS, turns to pink in the plug to the ECU loom.
                          Ok thanks, i have pretty much the information from different TRE pages. Will make a dynamic current output from a box i'am designing to emulate the diffrent resistors and wanted to revese engineer the input circuit.
                          After a quick calculation i can see the input is biased trough a 1K resistor up to the internal 5V supply in the ECU. See snap of calc sheet attached.
                          However the black/white earth, where does this go? Is it a hard ground that i could sink like 200mA into? Or is it clean filtred ground reserved for the GPS?
                          Roll on...
                            Oh no.. EXCEL!!!!!
                            I think Steve has found a new hetero-lifemate!
                              Oh no.. EXCEL!!!!!
                              Mm, I guess that would be a typical comment from someone who is less enlightend in how things work in real life
                              Ohh steve so you like Excel aswell
                              Real men do it.. --- use excel
