polished frame?
Hey dude...how do you get the rough stuff off of the middle part of the frame? Do you just use aircraft remover or do you sand?Custom Black with Multi-Color Metalflake 2000 TLR with Bitubo Rear Shock, Attack Rear Sets, Galfer Steel Braided Brake and Clutch Lines, BT-014 180 Rear Tire, TRE, PCII, BMC Air Filter, Yosh Stainless Full System, Joe V's Air Box Modification, Fan Switch Modification, Galfer Rear Wave Rotor, Hayabusa Gold Brake Calipers-Front and Rear, GSXR1000 Gauge, Daytona Temperature Gauge, CATS H.I.D. Headlights, No Cut Frame Sliders, Two Sided Fairing Stay, Extreme Graphics Undertail with Integrated Turn Signals, Polished Frame, Swingarm, Forks, Subframe, Steering Damper, Chrome Rims, Clear Clutch Cover, Gold Powdercoat on Triple Clamp, Clipons, Brake and Clutch Levers, Fairing Stay, Steering Damper Mounts, Rearsets, Passenger Pegs, Kick Stand, Calipers and Rotors, Hammerit Double Bubble Smoke Windscreen, Corbin Seat.
sand, sand, and sand some more. be careful if you use a coarse wheel, dont want to take too much off
Use a high speed cloth wheel in the end of a drill ... I couldnt get it looking very good doing it by hand or with a lambswool buff. I used a loose calico buff in a drill with red then white tripoli after sanding to 1500
And yes sand that vertical part.. its a bitch, same with the head stock.
