Deal mode plug on TLR
  • Deal mode plug on TLR
    Would someone please clue me in to where the dealer mod plug is on the TLR?
    Thanks!
    Under the passenger seat on the left side of the bike.
      common, a 2 min response, what are we running here? A boat load of female goats full of horny guys! Gotta do better than that!!!
      No really, thanks!
        what's a dealer mod plug?
          its a paper clip...
            um...what's it do?
            is there one on a tls?
              There is one on the TLS, behind the rear righthand panel, I just pulled mine into the trunk for ease of access.
              You bridge it out with a paper clip and the LCD display on the Tacho changes and shows any ECU fault codes if present. C00 is all clear, it also allows you to set your TPS. http://home.iprimus.com.au/stevebm/TLS_ECU.htm
                aaahh...thx!
                  Plug is in between the tail plastic and trunk compartment on the left side. Has two wires and should have a rubber cap on it.
                    Go to radio Shack.
                    Buy a $.50 micro switch.
                    Cut the Stock Plug off.
                    Splice the sire to recently purchased micro switch.
                    Voila! Full Time Dealer Mode switch with out having to worry about letting the paperclip touch any metal.
                    MUCH better than buying the Suzuki switch for how ever many $ they want.
                      or use electrica tape .01 on the paperclip .01 Voila! don't cut your stock wiring if you don't have too, it lowers resale.
