Anyway,I`ve got a 3.6" square fan(12 volt),50 cfm, that draws 20Ma(.20 amps) and would like to wire it so that it turns off when the key is off.Should I run the wires up to the ignition switch?.
CPU fan on TLR rectifier.........
I was told of a mod to put a largish cpu type fan on the rectifier to help cool it.After a days ride,my rectifier was pretty hot.
Anyway,I`ve got a 3.6" square fan(12 volt),50 cfm, that draws 20Ma(.20 amps) and would like to wire it so that it turns off when the key is off.Should I run the wires up to the ignition switch?.I AM CANADIANTags: None
For the TLR, there should be an empty plug up the front near the headlight that is used for a parking light in some markets, it's only hot when the ignition is on believe. Use that or splice into the fuel pump relay, in the same place you would for an ATRE, I only have pics and the location for an "S" though."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Originally posted by rupes
Good point tho.... I have mine mounted inside the tail. There is very little if any air movement ...hmmm"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
What is this noise you speak of...I don't think it would be noticable...due to the exhaust...you are running after market exhaust...If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason.
you could even mount up a 80mmcathode fan
How about a water cooling system? You could really overclock that puppy!"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man." - George Bernard Shaw
Originally posted by redbull
This mod has been around for years with Suzuki GS owners. I've heard it helps keep rectifyers alive. Can't hurt anything, but the noise could get annoying..
I AM CANADIAN
