Here I go again...
Here I go again...
My next project. Let's see who can put 2 & 2 together and guess what frame this is...?
Tags: None
Okay, I'll give you a hint - The same guy who designed this frame went on to design the 916 Ducati later in life...
Its an example of the very rare 'skinnious reartireous'2003 Blue and White TL1000R (The faster colors) Yoshimura Ti Cans, TRE, Custom Homemade Fender Eliminator, Hammerit Carbon Look Intake Covers, PC II, Fan Switch Mod. Yellow Box, Nissin Brake Caliper and Goodridge SS Brake Lines.
#1 STUNT FORUM SUPPORTER
Is it a Laverda of some sort?
The fram looks a bit to wide for a Twin. But an I3 would fit.TL1000R -99. Yellow/Black.
harrisMY MODS:
TO BE CONTINUED
Well the man that designed the 916 was Massimo Tamburini
Is this a Ducati Paso 750?
<a href="http://www.wunderground.com/global/stations/71887.html">
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/71887.gif">
