Billet oil filler caps
  • Billet oil filler caps
    For those that never read the Group buy section, I have plenty of leftovers of these. $19 +Shipping.
    All Suzuki's and some Aprilia's.
    Includes the proper o-ring.
    Properly sized, machined and finished. Not to be confused with Far East ebay sweatshop junk.
    Re: Billet oil filler caps
    Thanks Van. Got mine. So much nicer than the cheap Asian junk out there.
    BBOTM January 2011
      I'm guessing these are for the stock clutch cover, not the sexy Vandriver one? If it's for yours, I'll be needing one.
      -Matt
      "Too much horsepower is just about right." - Carroll Shelby
        These are for the stock Suzuki covers, but I have a smaller version for my Billet cover.
          Bump
          Still plenty left, but some colors are running low.
            Will it fit the drain plug?
              If I say yes, are you buying one?
                Got a black one for me?
                  Absolutely.
                    Certainly. A relatively simple preventative measure to avoid a stripped case, provided the plug threads give out before the case threads. Not to mention the holes, for easy safety-wiring.
                      It will fit?
                        It will fit?
                        The stock oil filler cap will not fit in the oil drain hole, but the oil filler cap for my clear clutch cover will. I'll PM you the other details.
                          Van,
                          This should be something that everyone gets if it will strip before the oil pan does. Spend a couple of $$ now, or feel the pain later.
                          Now if you could only make a solution to broken header bolts.....
                          BBOTM January 2011
                            That was quick! It's here, thanks.. looks excellent
                              Thanks, show your friends, I still have plenty.(All Suzuki's)
