Toby steering damper
  • Toby steering damper
    For sale is Toby steering damper in black. it has an oil leak and needs replacing seal. it is side mount type damper and will require a fork leg clamp to mount it. The damper is in great condition like new i would say (except for seal failure).
    40 + postage
    will post some pics later...
    MY BIKE: 1998 TLS 107.52 Hp 71 lb-ft.
    http://www.tlplanet.com/forums/showthread.php?t=92328
    Re: Toby steering damper
      rod looks slightly bent?
        Sorry Ged but I agree......
        People I will not deal with: tl1000swill or tlrwill or crazywheelie or whatever it decides to call himself.
          it just looks like that in this photo i thought the same thing after seeing this pic, but will check again for peace of mind
              PM sent T.L.
                much better. You might have moved the camera on the first image creating the "bent" illusion. That happens with cellphone cameras a lot, particularly the iPhone. Good luck on the sale.
                  I have one of these ( ex bimati) and they are excellent. very fine adjustments of damping and smooth . I'd rate them better than an ohlins.( i have one of those too)
                    Stu, is yours side mount type too? do you have any pics that shows how you mounted it? have you drilled your frame? (like Sam did on his race TLS?)
                      dibs T.L.
                        Second dibs if Terry doesn't get it!
                          Originally posted by TerryLemmons View Post
                          PM sent T.L.
                          pm replied
                            Cancel on that dibs. Looks like the wife's wearing the pants in the house today, and she said the car needs new tires
                              MRS slhawkins slhawkins
                              My bike mod list - Click here
